Document Help 6 years 1 month ago #14745
  • robertlforsyth
  • robertlforsyth's Avatar Topic Author
Using the Cordova code, is there docs or KB on how to manage/disable menu items or set the initial view of the player? Also, on the Android version, there is a popup dialog when loading a PDF across http, but NOT one for iOS. Is there a call for showing a 'loading' dialog/message for iOS?
Thanks in Advance!
- Robert
Document Help 6 years 1 month ago #14747
Hi
We've just fix an issue about hiding menu items, please pull from GitHub last commit so it should works well or shift this line from viewDidLoad to viewWillAppear method in RDLoPDFViewController class.
[self createToolbarItems];
For hiding menu items in Cordova you should use setToolbarEnabled in index.js
(Add these lines before RadaeePDFPlugin.open or it will not work)
RadaeePDFPlugin.setToolbarEnabled(
            enabled: false
        function (message) {
            console.log("Success: " + message);
        function (err) {
            console.log("Failure: " + err);
Right now there's no call for showing a loading dialog for iOS but it will be added
Document Help 6 years 1 month ago #14749
  • robertlforsyth
Thanks the new build worked to hide the toolbar. Are there any docs for how to customize the toolbar?
- Robert
Document Help 6 years 1 month ago #14750
  • robertlforsyth
Another question. I hid the toolbar, but when I set
enabled: true
the toolbar does not appear. Any thoughts? Also, is there a way to close the viewer by using the DoubleTap callback?
Document Help 6 years 1 month ago #14752
Hi Robert,
By using setToolbarEnabled you can't hide and show toolbar programmatically: you're going to set a parameter checked before PDF opening.
You could check some RadaeePDF Cordova's methods here that also include toolbar's customization.
Document Help 6 years 1 month ago #14753
  • robertlforsyth
I should have been more clear. When I added your call before I opened the doc, the toolbar disappeared. When I removed that call or changed it to enabled:true, the toolbar did not come back. I need the toolbar for the back button (To close the doc), but its not there anymore.
