zoom problem 12 years 11 months ago #3744
hi,
are you using the same project that you sent last time?
Is this a systematic error? in this case, can you describe me the steps to make happen this bug?
zoom problem 12 years 10 months ago #3821
  • truculent
in your sample project [demo] test zoom!
it not realy normal
it's buggy!
we want our zoom will normal :( [Like safari - Like good reader like all of Reader !]
some times zooms not work [not detect 2 finger or some thing Like it]!
can you change method of your zoom ?
please hurry up we must send our project to apple store wednesday :(
zoom problem 12 years 10 months ago #3894
  • truculent
where Are you :|
where is your support :| ?
your zoom is bugggggy :| :| :| :| : | :| : | :| :|
zoom problem 12 years 10 months ago #3895
in which condition do you have 2 finger detection problem?
Are you using a particular view mode or a particular PDF?
Are you using demo project or a custom version of it?
zoom problem 12 years 10 months ago #3896
the condition is:
touched point is 2, in TouchDown and TouchMove
zoom problem 12 years 10 months ago #3905
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Are you using UITapGetureRecognizer or UIPinchGestureRecognizer or other cocoa gesture function?
In PDFView class , there has function about zoom in zoom out,you did not need use other gesture function in PDFViewController which you use PDFView.
