zoom problem 12 years 11 months ago #3476
What's wrong?
Can you send me also PDFView class?
PDFV class seems to be ok (with the exception of last swiping = NO; in vGetDeltaToCenterPage, that is useless).
zoom problem 12 years 11 months ago #3479
  • truculent
zoom problem 12 years 11 months ago #3484
ok, you have to change some lines:
lines 764, 766, 776, 778 with:
[m_view vGetDeltaToCenterPage:pos.pageno - 1 :&m_swipe_dx :&m_swipe_dy :YES];
lines 107, 690, 788 (the last call in onSwipe method, because is for vertical swipe) with:
[m_view vGetDeltaToCenterPage:pos.pageno :&m_swipe_dx :&m_swipe_dy :NO];
the last line is for swipe capture, line 672:
if( sdel < 0.1 && (sdx > 20 || sdx < -20 || dy > 20 || sdy < -20) )//swipe
Now it should be ok
zoom problem 12 years 11 months ago #3485
For lines 764, 766, 776, 778 pos.pageno - 1/pos.pageno + 1 don't have to change, you only have to add :YES
zoom problem 12 years 11 months ago #3639
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
When touches is end PDFView will do this.
- (void)touchesEnded:(NSSet *)touches withEvent:(UIEvent *)event
if( m_type == 3 || m_type == 4 )
struct PDFV_POS pos;
[m_view vGetPos:&pos :m_w/2 :m_h/2];
[m_view vGetDeltaToCenterPage:pos.pageno :&m_swipe_dx :&m_swipe_dy];
Is other place in touch event you use VGetDeltaToCenterPage Function?
zoom problem 12 years 11 months ago #3731
  • truculent
dear strong lee & emanuele
after you fix my zoom problem [not compleatly we are going to bad bug!] ---> change delate center method
-(void)vGetDeltaToCenterPage:(int)pageno :(int *)dx :(int *)dy :(BOOL)swiping;
and in .m file I change the method implementation:
-(void)vGetDeltaToCenterPage:(int)pageno : (int *)dx : (int *)dy :(BOOL)swiping
if (!swiping) {
if( m_pages == NULL || m_doc == NULL || m_w <= 0 || m_h <= 0 || m_scale > m_scale_min) return;
PDFVPage *vpage = m_pages[pageno];
int left = [vpage GetX] - m_page_gap/2;
int top = [vpage GetY] - m_page_gap/2;
int w = [vpage GetWidth] + m_page_gap;
int h = [vpage GetHeight] + m_page_gap;
int x = left + (w - m_w)/2;
int y = top + (h - m_h)/2;
*dx = x - m_x;
*dy = y - m_y;
after zoom & paging reader going crazy & show & change every page on pdf :-o [start from page current & going to page N ]!!!!
in other word our zoom problem not compleate fix!
can you help us for fix it ?
our book is RTL !
we want to simple zoom! and if in zoom mode user want to paging not bug happend :(
