hegiht problem 13 years 4 days ago #3365
  • truculent
dear radaee i want to hide my navigation bar but when i hide it with single tap method
it's work fine but problem is: [empty space ]
i want to my content of pdf fit my screen how i can do it ?
i want to change my pdf view frame :)
i goto PDFView & delete *m_scaleValue from
m_w = frame.size.width *m_scale ;
m_h = frame.size.height*m_scale;
- (id)initWithFrame:(CGRect)frame
self = [super initWithFrame:frame];
if (self)
m_doc = NULL;
m_view = nil;
m_scale = [[UIScreen mainScreen] scale];
m_w = frame.size.width;
m_h = frame.size.height;
self.userInteractionEnabled = YES;
self.multipleTouchEnabled = YES;
[self resignFirstResponder];
m_swipe_dx = 0;
m_swipe_dy = 0;
return self;
it work but when open pdf it;s not work but when go to add note controller & back agian it's work :(
then go to m_view = [[PDFView alloc] initWithFrame:CGRectMake(0, 0, rect.size.width, rect.size.height-20-hi)];
& delete -20-hi but it's not work for first [it need to rotate the screen]
Last edit: by patel_patel_patel.
hegiht problem 13 years 4 days ago #3375
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Did you adjust the frame in singleTap action?
Last edit: by GoliNeneswees.
hegiht problem 13 years 3 days ago #3379
  • truculent
no
i change the frame in
-(int)PDFOpen:(NSString *)path : (NSString *)pwd
m_view = [[PDFView alloc] initWithFrame:CGRectMake(0, 0, rect.size.width, rect.size.height)]; // delete your value !
it's work but need a rotate to apply :(
hegiht problem 13 years 3 days ago #3388
  • stronglee
Is this view add to superview?
[self.view addSubview:m_view];
hegiht problem 13 years 3 days ago #3391
you can try to move the entire view when you hide/show the navBar, something like:
CGRect tempFrame = self.view.frame;
tempFrame.origin.y -= self.navigationController.navigationBar.frame.size.height;
[self.view setFrame:tempFrame];
on single tap event
