duplicate note problem 13 years 11 hours ago #3413
  • truculent
hi i add new button too toolbar for add note in custom position !
i set touch x,y & when user press save button i pass x&y to pos x & pos y!
it's work Like charm :)
but my problem is when open a creatED note & again press save button it create new Note :(
-(void)OnSaveTextAnnot:(NSString *)textAnnot
[m_view vAddTextAnnot:posx :posy :textAnnot];
wantAddNote = false;
how i can fix it ?
i want only update content of note :(
Last edit: by patel_patel_patel.
duplicate note problem 13 years 3 hours ago #3417
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
[m_view vAddTextAnnot:posx :posy :textAnnot]; this method will create a new TextAnnot icon.
when press addnote button in toolbar,
this method just use to create new textAnnot,
when you single tap the textAnnot icon ,use a new method to Modify textAnnot
-(void)vModifyTextAnnot:(int)x :(int)y :(NSString *)text
struct PDFV_POS pos;
[m_view vGetPos:&pos:x:y];
if(pos.pageno>=0)
PDFVPage *vpage = [m_view vGetPage:pos.pageno];
PDF_PAGE page = [vpage GetPage];
float pdf_x = [vpage ToPDFX:x :[m_view vGetX]];
float pdf_y = [vpage ToPDFY:y :[m_view vGetY]];
if( page != NULL )
PDF_MATRIX mat = [vpage CreateMatrix];
//PDF_ANNOT annot = Page_getAnnot( page, Page_getAnnotCount(page) - 1 );
PDF_ANNOT annot = Page_getAnnotFromPoint(page, x, y);
Page_setAnnotPopupText(page, annot, [text UTF8String]);
Matrix_destroy(mat);
The following user(s) said Thank You: patel_patel_patel
