arabic save problem! 12 years 11 months ago #3477
  • truculent
i found a bug!
in your last version you add note feature!
we work on it! add remove/modify it!
but now we give a bad problem ! when add arabic/persian note it's not save !
we check your PDFviewer sample [last version]!
when add arabic note after save it when press note icon not do any thing!
check pdf with preview the note is empty!
funny note : if you enter 1 character for example 'a'then append arabic charecter it's going to save!
arabic save problem! 12 years 11 months ago #3487
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Is this arabic text? :huh: "ينيخثنستب" I‘ll check this problem.
The following user(s) said Thank You: patel_patel_patel
arabic save problem! 12 years 11 months ago #3489
  • truculent
yup!
anyyyy character in arabic or persian !
but if enter 1 english charecter and append arabic charecter it's seems okay :(
arabic save problem! 12 years 11 months ago #3512
  • truculent
any solution ?
arabic save problem! 12 years 11 months ago #3513
  • stronglee
This bug was fixed ,there will release a new library. With the new library you can save arabic character. :)
arabic save problem! 12 years 11 months ago #3514
  • truculent
thank you!
but i fix it by little code :D ---->
        if ([[textAnnot substringToIndex:0] isEqualToString:@" "]) {
            textAnnot = [textAnnot substringFromIndex:1]; // when show note, delete space character
        NSMutableString * tempTextAnnot = [[NSMutableString alloc] initWithString:textAnnot];
        [tempTextAnnot insertString:@" " atIndex:0]; // add space character for fix this problem :)
        textAnnot = [tempTextAnnot copy];
        [m_view vModifyTextAnnot:tempTouchX :tempTouchY :textAnnot];
upload7.ir/images/64925342200789951615.png
i suggest you fix another problems :) or add feature Like change scale of annot or ....
Last edit: by patel_patel_patel.
