Compile error when using SDK in NimbleKit project 12 years 11 months ago #3718
  • Henry
  • Henry's Avatar Topic Author
Dear AndroidPDF:
I used Nimblekit (nimblekit.com) to Develop APP originally, and now I want to use your PDFViewer SDK in my Nimblekit project.
But when I link library "libRDPDFLib.a" and import "PDFLib", it compiles error.
The error message is "Apple Mach-O Linker Error", and part of the information is below:
  "___gxx_personality_v0", referenced from:
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFAcroForm.o)
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFAction.o)
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFAnnot.o)
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFCMap.o)
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFColorSpace.o)
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFCommon.o)
   Dwarf Exception Unwind Info (__eh_frame) in libRDPDFLib.a(PDFDoc.o)
  "_absolute32", referenced from:
   _ftc_inode_weight in libRDPDFLib.a(ftcache.o)
   ld: symbol(s) not found for architecture i386
  clang: error: linker command failed with exit code 1 (use -v to see invocation)
May you help me to solve this problem, thank you very much.
Best Regards,
Henry
Compile error when using SDK in NimbleKit project 12 years 11 months ago #3723
the core need libc
Compile error when using SDK in NimbleKit project 12 years 10 months ago #3996
  • jdrukman
  • jdrukman's Avatar
I can't get an app using your PDF lib to link. Same error as above. I added libc, libc++ and libstdc++ to Link Binary With Libraries build phase, but the error keeps happening. Please let me know how to fix it.
Compile error when using SDK in NimbleKit project 12 years 10 months ago #3997
using shared library wrapping in Xcode?
Compile error when using SDK in NimbleKit project 12 years 10 months ago #3999
  • jdrukman
  • jdrukman's Avatar
I just followed the directions in the ios_readme.pdf. I don't know what you mean by "shared lib wrapping" so probably not.
Compile error when using SDK in NimbleKit project 12 years 10 months ago #4003
OK, if just absolute32 is absent.
you can write the function by yourself, like:
extern "C" int absolute32(int v)
  if( v < 0 ) return -v;
  else return v;
in C++
  else return v;
in C
