Semantic issue while building 12 years 5 months ago #4114
  • abi_inflo
  • abi_inflo's Avatar Topic Author
I followed the instructions given in the help.pdf file but getting the following semantic issue while building in XCode 5 in PDFVThread.h file. I did not made any changes in this file.
Error:
Control reaches end of non-void function static void *thread_route(void *para);
Kindly reply me with a solution.
Abilash.G
Semantic issue while building 12 years 5 months ago #4117
  • abi_inflo
I can able to solve the semantic issue but now I am getting the following linker issue.
Undefined symbols for architecture i386:
"_absolute32", referenced from:
_ftc_inode_weight in libRDPDFLib.a(ftcache.o)
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Kindly tell me the procedure for adding the library to my project.
Abilash.G
Semantic issue while building 12 years 5 months ago #4119
  • sbalajisuk
  • sbalajisuk's Avatar
Hi, Can you please give a solution to this problem. We recommended that our company buy your iOS license. Now we are stuck with this problem. We need to have a build tonight for our mobile app. We will be really greatful for your solution for this problem and the problem mentioned in another post by abi_inflo regarding the fonts getting changed.
Balaji
Semantic issue while building 12 years 5 months ago #4120
we are working to solve compatibility issue with Xcode5 and iOS7.
We expect to publish a new demo version early next week.
Semantic issue while building 12 years 5 months ago #4122
  • abi_inflo
I tried and found that in my application I had -ObjC and -all_load linker flags enabled already. So Once I removed these flags, the app is able to build without this issue. Is there any other way to solve this issue?
Even though we can able to build the app, when the APP_INIT method is called, the app hangs at the following function call. It makes my application to hang infinitely. Kindly reply us with a solution as soon as possible since we have to deploy the changes to our app.
function call that hangs: "if( Global_SaveFont("Arial", dst) )"
Abilash.G
Semantic issue while building 12 years 5 months ago #4155
  • sbalajisuk
Hi Radaee friends, Kindly reply to abi's question. We are very urgently in need of the solution. I know you are in the process of getting a new demo version, But the issue, Abi posted happened when we tried to integrate the pdf reader into our app. It happens in both iOS6 and iOS7. Please help us.
