Watermark removal 12 years 9 months ago #4218
  • abi_inflo
  • abi_inflo's Avatar Topic Author
I bought the professional license for pdf reader IOS version and applied the key on APP_INIT() method. But still the water mark is not removed. Is there anything else we need to do to remove the license? Also the library libRDPDF.lib is of 10 MB size. Is there any chance to reduce the size? as we are not going to implement all the features.
Thanks in advance,
Abilash.G
Watermark removal 12 years 9 months ago #4219
the license active is tested.
maybe some problem in your codes.
if any problem, you can send me mail: This email address is being protected from spambots. You need JavaScript enabled to view it. or send mail to support.
about library size:
the library both include ARM and x86, so it is 10M
but when you link, XCode shall just link ARM part, and will reduce size to your APP.
Watermark removal 12 years 9 months ago #4225
  • abi_inflo
I sent an email to the id mentioned. Please reply.
