Copy function not working correct 12 years 7 months ago #4597
  • sahli.wa.skumar
  • sahli.wa.skumar's Avatar Topic Author
When i long click on viewer and select option copy, after that when i select two three lines only a word is selected?
Please suggest.
Copy function not working correct 12 years 7 months ago #4604
We test copy function and It works normally.
Here is a screenshot using copy function in demo project.
Have you modified the project?
Copy function not working correct 12 years 7 months ago #4605
  • sahli.wa.skumar
Yes it work correctly.Thankyou
