Problem with Links on iPad Air 12 years 3 months ago #5825
  • hassan31
  • hassan31's Avatar Topic Author
I'm using your PDF Kit. And I'm facing a problem. In simple iPad, when I tap on links in the pdf, it works fine, but in case of iPad Air links are not working, I mean links are not open when I tap on them using iPad Air.
Can you please tell me the solution of it, and can you assist me that Where I can find the code when I tap on the link.
Best Regards:
Hassan
Problem with Links on iPad Air 12 years 3 months ago #5842
  • hassan31
Best Regards:
Hassan
Problem with Links on iPad Air 12 years 3 months ago #5845
we would make some tests with the pdf that you're using to test the demo project.
can you send it to us?
Problem with Links on iPad Air 12 years 3 months ago #5846
  • hassan31
Okay, I'll send it to you, But in the code can you tell me where onTap of the link functionality is implemented. So that I can also test on my side as well.
Problem with Links on iPad Air 12 years 3 months ago #5847
in RDPDFViewControlloer.m there is delegate method OnOpenURL, where you can handle the url.
in PDFView.m there is onSingleTap method, where you can handle singleTap and the annotation (if there is one)
Problem with Links on iPad Air 12 years 3 months ago #5881
  • hassan31
Here is the link, that you can download it for free and test that why links are not working on iPad Air.
itunes.apple.com/us/app/emerce-store/id827465783?ls=1&mt=8
