Layout Parameter & Fit-Modes 12 years 2 months ago #6187
  • offlinebouncer
  • offlinebouncer's Avatar Topic Author
How do I set LayoutParameter and FitMode in iOS-SDK?
We need this to show cover in PDF correct (facing pages).
Layout Parameter & Fit-Modes 12 years 2 months ago #6203
like this code in [PDFView vOpen]:
bool horz[1];
horz[0] = false;
m_view = [[PDFVDual alloc] init:false :horz:1 :NULL :0];
Layout Parameter & Fit-Modes 12 years 2 months ago #6204
  • offlinebouncer
The code does not work:
bool horz[1]; -> Expected Expression
horz[0] = false; -> Use of undeclared Identifier "horz"
Layout Parameter & Fit-Modes 12 years 2 months ago #6205
  • offlinebouncer
OK...it seems to be a compiler-bug. You cannot declare a variable on the first line inside a :case.
I changed the code to this, which compiles:
defView = 3;
bool horz[1];
horz[0] = false;
m_view = [[PDFVDual alloc] init:false :horz :1 :NULL :0];
But: The view is still wrong! Page 1 (Cover) of PDF must be viewed allone in DualView!
Layout Parameter & Fit-Modes 12 years 2 months ago #6206
  • offlinebouncer
You postet wrong code! I figured it out myself now:
bool horz[1];
horz[0] = false;
m_view = [[PDFVDual alloc] init:false :NULL :0 :horz :1];
Layout Parameter & Fit-Modes 12 years 2 months ago #6207
  • offlinebouncer
How about setting fit modes?
