Rendering issue for a pdf document 11 years 11 months ago #6884
  • vinayr
  • vinayr's Avatar Topic Author
I am using trial version of Radaee . After running on iPad with a pdf document of 28 pages, it's UI getting stucked while zooming and also crashing if I tap on screen after first zoom. The rendering quality is very poor. Does PDF rendering follows Tile-based rendering technique or it just renders the pdf at once as image? We are testing with a PDF having resolution more than 4000x4000 points.
As we know that for Large resolution image rendering, we need to use CATileLayer instead of UIImageView or views drawRect: method, does this viewer follow that?
Thanks in advance.
Rendering issue for a pdf document 11 years 11 months ago #6892
can you send to us your test pdf?
we will do some test with it
Rendering issue for a pdf document 11 years 11 months ago #6896
  • vinayr
Add File button is not working so how can i add file .
Rendering issue for a pdf document 11 years 11 months ago #6897
try with Internet Explorer browser
Rendering issue for a pdf document 11 years 11 months ago #6898
  • vinayr
We are using mac for iOS development thats why we don't have internet explorer. So how can we upload with that?
Rendering issue for a pdf document 11 years 11 months ago #7032
the SDK doesn't use CATileLayer to render the pdf pages
