From PDFPoint to view point 11 years 10 months ago #7078
  • Rossi
  • Rossi's Avatar Topic Author
Hi, onSelEnd I convert the start and the end point to pdf point and save it.
After, I need the corresponding point in the view (portrait or landscape), how i ca do it?
Last edit: by Abdikayrov.
From PDFPoint to view point 11 years 10 months ago #7079
you can try with:
PDFVPage *vpage = [m_view vGetPage:page];
CGPoint viewPoint = CGPointMake([vpage ToPDFX:point.x], [vpage ToPDFY:point.y]);
From PDFPoint to view point 11 years 10 months ago #7094
  • Rossi
if i have the pdf open with ipad in portrait mode it work, but if i have the ipad in landscape the y it wrong, the PDFView is in PDFVDual mode.
From this pdf point
x1(143.7574,568.9045);
x2(219.6855,568.9045);
return this view point
x1(203.340836,-2.770934)
x2(313.812866,-2.770934)
From PDFPoint to view point 11 years 10 months ago #7174
you can try to get points directly from a page, with:
-(int)GetVX:(float) scrollx;
-(int)GetVY:(float) scrolly;
methods, in PDFVPage class
From PDFPoint to view point 11 years 9 months ago #7321
  • Rossi
No, it doesn't work.
I need to redraw a markup annotation made in portrait mode when i open the pdf in landscape mode.
There is same other way to do this?
