Annot render problem on device 11 years 10 months ago #7233
  • shivkant
  • shivkant's Avatar Topic Author
Facing a problem of annotation rendering on device. It works on simulator and even I get the total annotation count on simulator. But on device it does not add any annotation. Please help.
Thanks in advance.
Annot render problem on device 11 years 10 months ago #7236
do you mean add annotation?
plz check [m_doc CanSave];
Annot render problem on device 11 years 10 months ago #7251
  • shivkant
Yes on adding notation, When ever I run my app on simulator I able to add a notations like highlighter/Underline/StrikeOut, but when I run the app on device it does not add the notations. after adding notation it did not render notations and gives notation count 0 on particular page.
Even I downloaded demo code again and call PDFGlobal class method
bool isSuccess = Global_activePremium("PackageName", "Company name", "mail id", "license key");
with appropriate parameters(those I got after purchasing license key) it returns 1, that means my credentials are right. It works on simulator fine. and when I use same code on my device, annotation features not working.
Please help.
Annot render problem on device 11 years 10 months ago #7252
  • shivkant
[m_doc CanSave]; returns 0, after activate with premium credentials.
Please help.
Annot render problem on device 11 years 10 months ago #7253
there are 3 condition:
1. PDFDoc object not init.
2. PDFDoc object not open or create, or closed.
3. the file opened is not writeable.
Annot render problem on device 11 years 10 months ago #7257
  • shivkant
PDFDoc object init methods calls in these methods
but when I call
[m_doc save]; returns 0 after calling m_doc = [[PDFDoc alloc] init];.
So I know this may be the problem. but how to resolve it
here are those method copied from demo code.
-(int)PDFOpen:(NSString *)path : (NSString *)pwd
[self PDFClose];
PDF_ERR err = 0;
err = [m_doc open:path :pwd];
switch( err )
case err_ok:
break;
case err_password:
return 2;
break;
default: return 0;
CGRect rect = [[UIScreen mainScreen]bounds];
//GEAR
if (![self isPortrait] && rect.size.width < rect.size.height) {
float height = rect.size.height;
rect.size.height = rect.size.width;
rect.size.width = height;
//END
float hi = self.navigationController.navigationBar.bounds.size.height;
NSString *iosversion =[[UIDevice currentDevice]systemVersion];
if([iosversion integerValue]>=7)
m_view = [[PDFView alloc] initWithFrame:CGRectMake(0, 0, rect.size.width, rect.size.height)];
else
m_view = [[PDFView alloc] initWithFrame:CGRectMake(0, 0, rect.size.width, rect.size.height-20-44)];
[m_view vOpen:m_doc: self];
pagecount =[m_doc pageCount];
[self.view addSubview:m_view];
m_bSel = false;
return 1;
-(void)vOpen:(PDFDoc *)doc :(id<PDFVDelegate>)delegate
//GEAR
[self vClose];
//END
m_doc = doc;
//g_PDF_ViewMode =2;
//defView =2;
bool *verts = (bool *)calloc( sizeof(bool), [doc pageCount] );
switch(defView)
case 1:
m_view = [[PDFVHorz alloc] init:false];
break;
case 2:
m_view = [[PDFVHorz alloc] init:true];
break;
case 3:
//for dual view
m_view = [[PDFVDual alloc] init:false :NULL :0 :NULL :0];
//for single view
//m_view = [[PDFVDual alloc] init:false :NULL :0 :verts :Document_getPageCount(doc)];
break;
case 4:
//for dual view
m_view = [[PDFVDual alloc] init:true :NULL :0 :NULL :0];
//for single view
//m_view = [[PDFVDual alloc] init:true :NULL :0 :verts :Document_getPageCount(doc)];
break;
default:
m_view = [[PDFVVert alloc] init];
break;
free( verts );
m_type = defView;
struct PDFVThreadBack tback;
tback.OnPageRendered = @selector(OnPageRendered:);
tback.OnFound = @selector(OnFound:);
self.backgroundColor = [UIColor colorWithRed:0.7f green:0.7f blue:0.7f alpha:1.0f];
[m_view vOpen:doc :4 :self: &tback];
[m_view vResize:m_w :m_h];
m_timer = [NSTimer scheduledTimerWithTimeInterval:0.03
target:self selector:@selector(timerFireMethod:)
userInfo:nil repeats:YES];
[[NSRunLoop currentRunLoop]addTimer:m_timer forMode:NSDefaultRunLoopMode];
m_status = sta_none;
m_ink = NULL;
m_modified = false;
m_rects = NULL;
m_rects_cnt = 0;
m_rects_max = 0;
m_ellipse = NULL;
m_ellipse_cnt = 0;
m_ellipse_max = 0;
m_cur_page = -1;
m_delegate = delegate;
It is happing in currently downloaded demo code. annotation works on simulator but not on device.
Please help.
