Annot render problem on device 11 years 10 months ago #7282
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Try run download demo without modify bundle strings .
And check if name same with bundle identfier in TARGETS->General,
Such like com.radaee.pdf.xxxxxxxxx
Annot render problem on device 11 years 10 months ago #7287
  • shivkant
  • shivkant's Avatar Topic Author
Hi, I downloaded again and test it on my iPad and iPhone without modifying the bundel identifier, but got same problem :(
Annot render problem on device 11 years 10 months ago #7290
  • shivkant
Hi .. Could you please send me the demo code that you already tested on your device ?
my mail id is This email address is being protected from spambots. You need JavaScript enabled to view it.
Annot render problem on device 11 years 10 months ago #7298
  • stronglee
Hi,shivkant
I just download the demo from www.androidpdf.mobi/download/download-ios iospdfviewer2.2.0.zip,
and without nothing modified it works in my iphone5s(ios8) and ipad4(ios7), could try reboot your xcode and computer, and delete PDFViewer app from you device, then try run demo to your device again.
Annot render problem on device 11 years 10 months ago #7299
  • shivkant
Are you able to add notates on the doc ?
I Download fresh demo code, restart my makbook, Xcode and my iPad. and delete apps from iPad but did not get expected result .. :(
I tried all that you suggest but whenever i tried to add notate like press drawing button it shows a pop up says
"File is Readonly".... and whenever I add any annot like under line or highlight, It does not do any thing.. ?
Annot render problem on device 11 years 10 months ago #7300
  • stronglee
Set a break point at PDFView.m
Method -(bool)vInkStart
check [m_doc canSave] return value.
And Could you upload the document readonly to me.
