saving markup using core data 11 years 6 months ago #8381
  • t.revor
  • t.revor's Avatar Topic Author
Hi Radaee and team!!!!!
I tried saving markup in DB with no success,, it does not give error, but when i open my db the column that is suppose to store the markup is always empty.
please help.
thanx in adv..
saving markup using core data 11 years 5 months ago #8412
first you should check if the code that you're using to save data is correct (try to save sample data); then use markup getters to save the markup position (I think you can't save directly CGRect type).
