Check boxes are very hard to check 11 years 2 months ago #8929
  • bhagyashree
  • bhagyashree's Avatar Topic Author
To select check box in editable pdf format is very hard in normal as well as zoom mode
Last edit: by bhagyashree.
Check boxes are very hard to check 11 years 3 weeks ago #9178
  • bhagyashree
We are waiting for updates on this.
Feedback much appreciated.
Thanks!
Check boxes are very hard to check 11 years 3 weeks ago #9185
are you trying a specific pdf file? can you share it?
I think it could be only due to the object size
