Wrapper - render without font and exception 11 years 1 month ago #9023
  • leonardors
  • leonardors's Avatar Topic Author
I wrapper some features of Radaee, creating methods that create images only, removing the zoom of the components and all other features. I did the codes, but to run some files had different results:
- When running a file without embedded fonts, the render shows the PDF without the sources.
- When running other files, one execption is generated.
- Other files, functions normally.
I have attached the project from mistakes.
Thank you.
Wrapper - render without font and exception 11 years 1 month ago #9024
  • leonardors
I found error!!
In PdfRadaeeMemoryStreamWrapper
Incorrect code
-(bool)seek:(unsigned long long)pos
int nPos = (int)pos;
if (pos > [self position] || nPos < 0){
return NO;
position = nPos;
return YES;
Correct code
if (pos > [self length] || nPos < 0){
return NO;
position = nPos;
return YES;
Wrapper - render without font and exception 11 years 1 month ago #9025
About missing fonts: have you included cmaps and fdat folders in your project?
Wrapper - render without font and exception 11 years 1 month ago #9026
  • leonardors
Everything was related to the stream
