Add custom properties and methods 10 years 10 months ago #9563
  • tanvi
  • tanvi's Avatar Topic Author
I need to add custom properties and methods for PDFAnnot for mapping them with my objects.
I have rtried doing the same, but he property returns nil.
The following user(s) said Thank You: pfrank
Add custom properties and methods 10 years 10 months ago #9580
can you give an example of what you have done?
Add custom properties and methods 10 years 10 months ago #9583
  • tanvi
Hi Emanuele,
I have added a custom property, for example "ABC" and also relative methods like setABC and getABC.
So while I'm creating a new annotation (PDFAnnot object) I want to set the value of "ABC" as part of PDFAnnot class and retrieve it later.
Right now i see just 2 properties in the class PDFAnnot and they are PDF_ANNOT m_handle and PDF_PAGE m_page. I want to add my property over here.
Add custom properties and methods 10 years 10 months ago #9585
ok, as you can see in the PDFAnnot implementation, the annot informations are retrieved using library methods, that can read/write the annotation stored in the pdf file.
If you want to add custom properties, you have to use existing library methods to set/get values.
The following user(s) said Thank You: tanvi
Add custom properties and methods 10 years 10 months ago #9599
  • tanvi
Thanks Emanuele!
Also please if you can specify which are the properties or get/set methods which are currently unused by RadaeePDF, so that any changes made by me should not affect the internal code.
Add custom properties and methods 10 years 10 months ago #9611
You can modify the demo project as you prefer.
You can create new methods or make changes; in the second case, I suggest to search in the project where the method is used.
