CropBox and MediaBox 10 years 10 months ago #9600
  • tanvi
  • tanvi's Avatar Topic Author
I'm unable to get the CropBox and MediaBox.
I know the methods used are Page_getCropBox and Page_getMediaBox, but I don't know how can I implement them.
CropBox and MediaBox 10 years 10 months ago #9610
the best way to use these methods, is to create two methods in PDFObjc that call native lib's methods.
In PDFPage implementation, something like:
-(PDF_RECT)getPageCropBox
    PDF_RECT rect;
    Page_getCropBox(m_page, &rect);
    return rect;
-(PDF_RECT)getPageMediaBox
    PDF_RECT rect;
    Page_getMediaBox(m_page, &rect);
    return rect;
then, you can use these methods in this way:
PDFPage *page = [m_doc page:1];
    PDF_RECT rect1;
    PDF_RECT rect2;
    rect1 = [page getPageCropBox];
    rect2 = [page getPageMediaBox];
The following user(s) said Thank You: tanvi
CropBox and MediaBox 10 years 9 months ago #9741
  • aurgir
  • aurgir's Avatar
Page_getCropBox and Page_getMediaBox return false every time I call it. Is it normal ?
CropBox and MediaBox 10 years 9 months ago #9747
I tried the code above, and it seems to work correctly.
Are you using the same code?
CropBox and MediaBox 10 years 9 months ago #9749
checked codes, and some condition:
--at least standard license actived.
--valid Page handler pass.
--valid pointer of rect struct pass.
