Changing text color for Page_addAnnotEditbox2 10 years 9 months ago #9701
  • mobileAsd
  • mobileAsd's Avatar Topic Author
We are using the iOS function Page_addAnnotEditbox2 to create the textbox in our documents. There should be parameter for the text color according to the API, however it doesn't work. Could The same color value is successfully used for another function Page_addAnnotMarkup2, could you please help have a look in that issue? Thanks.
Changing text color for Page_addAnnotEditbox2 10 years 9 months ago #9709
I checked Page_addAnnotEditbox2 method, and also text_clr param works correctly (I used this color format: 0xFF00FF00).
Which library version are you using?
Changing text color for Page_addAnnotEditbox2 10 years 9 months ago #9711
  • mobileAsd
We are using the version 3.3.7, thanks.
Changing text color for Page_addAnnotEditbox2 10 years 9 months ago #9729
Here is the sample method used to check the feature in PDFView class:
- (void)addEditTextBox
    struct PDFV_POS pos;
    [m_view vGetPos:&pos :100 * m_scale :100 * m_scale];
    if(pos.pageno>=0)
        PDFVPage *vpage = [m_view vGetPage:pos.pageno];
        if( !vpage ) return;
        PDFPage *page = [vpage GetPage];
        if (!page) {
            return;
        m_modified = true;
        PDF_RECT rect;
        rect.top = 100;
        rect.left = 100;
        rect.bottom = 150;
        rect.right = 350;
        bool ret = [page addAnnotEditbox:&rect :0xFF000000 :3 :0xFFFFFFFF :12 :0xFF00FF00];
        PDFAnnot *annot = [page annotAtIndex: [page annotCount] - 1];
        [annot setEditText:@"TEST"];
        [m_view vRenderSync:pos.pageno];
        [m_doc save];
And here is the addAnnotEditbox method created in PDFObjc class to call Page_addAnnotEditbox2
-(BOOL)addAnnotEditbox:(const PDF_RECT *)rect :(int) line_clr :(float) line_w :(int) fill_clr :(float) tsize :(int) text_clr
    return Page_addAnnotEditbox2(m_page, rect, line_clr, line_w, fill_clr, tsize, text_clr);
I hope this sample will help you
The following user(s) said Thank You: mobileAsd
Last edit: by emanuele.
Changing text color for Page_addAnnotEditbox2 10 years 9 months ago #9750
  • mobileAsd
It seems the alpha value for the line_clr must be 0xFF, if not text color will not be changed, thanks.
