Thumbnail doesn't appear 10 years 3 months ago #10549
  • colliot
  • colliot's Avatar Topic Author
I'm blocking on a little problem and can't understand what i am doing wrong:
I'm trying to add your PDFThumbnail to my custom application with the piece of code:
    CGRect boundsc = [[UIScreen mainScreen]bounds];
    if (![self isPortrait] && boundsc.size.width < boundsc.size.height) {
        float height = boundsc.size.height;
        boundsc.size.height = boundsc.size.width;
        boundsc.size.width = height;
    int cwidth = boundsc.size.width;
    int cheight = boundsc.size.height;
    float hi = self.navigationController.navigationBar.bounds.size.height;
    if(SYS_VERSION>=7.0) {
        m_thumbview = [[PDFThumbView alloc] initWithFrame:CGRectMake(0, cheight-50, cwidth, 50)];
    } else{
        m_thumbview = [[PDFThumbView alloc] initWithFrame:CGRectMake(0, cheight-hi-50-20, cwidth, 50)];
    [m_thumbview vOpen :m_doc :self];
    [self.view addSubview:m_thumbview];
    return 1;
but it doesn't appear...
Could i send you my sample code in order to understand what went wrong?
By advance thanks
Thumbnail doesn't appear 10 years 2 months ago #10559
is your m_doc correctly initialized?
You should call [m_doc open:path :pwd]; somewhere before add the thumbview
