Display Single vertical page. Wrong slide 10 years 2 months ago #10616
  • flavio841
  • flavio841's Avatar Topic Author
When I view the pdf vertically on one page , each page is centered incorrectly. In practice, it also sees the start of the next. In the attached image it is very clear. How do I set this thing so it does not happen again ? Not much I know the library, and then all the information is useful .
Display Single vertical page. Wrong slide 10 years 2 months ago #10623
can you share your pdf file? we will check it to better understand the issue
Display Single vertical page. Wrong slide 10 years 1 month ago #10663
  • flamer
  • flamer's Avatar
Last edit: by flamer.
Display Single vertical page. Wrong slide 10 years 1 month ago #10697
in vertical render mode, the default behavior is to fit the page using width and the page scroll is continuos, for that reason also the next page is visible.
I suggest to change the render mode, for example to "double page left" mode.
Using demo app, you can change the render mode in setting tab/default view mode.
