How to use PDFopenMem? 10 years 1 month ago #10785
  • Shades
  • Shades's Avatar Topic Author
Could you please tell me how could I open PDF from OpenMem ? (I need an example please )
Thank you
How to use PDFopenMem? 10 years 1 month ago #10786
I suggest you to check RDPDFReader, here you will find the AdvanceAct, at the end of this class you will find an example of OpenMem in comments.
For more info check this www.radaeepdf.com/documentation/javadocs...:A-java.lang.String-
The following user(s) said Thank You: Shades
How to use PDFopenMem? 10 years 1 month ago #10788
you could take a look to this Knowledge Base Article that shows how to open a file with openMem.
I also suggest the article that shows how to open a pdf from URL
How to use PDFopenMem? 10 years 1 month ago #10789
  • Shades
OK thank you for your quick reply :)
