help.pdf in licensed copy of SDK 9 years 11 months ago #10981
  • rsimpson182
  • rsimpson182's Avatar Topic Author
Greetings,
I recently purchased a license, and during the iOS implementation process, I noticed that the SDK will copy over a file named "help.pdf" to the documents directory at the start of the application lifecycle. Is there a way to stop this file form being moved to the documents directory, or should I just ignore the file while searching for currently installed PDF files?
help.pdf in licensed copy of SDK 9 years 11 months ago #10997
the demo project handle the copy of help.pdf in viewDidLoad method of RDFileTableController ([[NSFileManager defaultManager] copyItemAtPath:hf toPath:documentPath error:nil];).
You can remove that slice of code to stop the help.pdf copy
