Can't draw a point for annotation 9 years 10 months ago #11225
  • Shades
  • Shades's Avatar Topic Author
I have a strange issue.I can't draw a point it's always a line.The code below is for drawing .
-(void)drawInk:(CGContextRef)context
  if( m_status == sta_ink && m_ink )
        NSLog(@"g_ink_color = %d",g_ink_color);
        int cnt = [m_ink nodesCount];
        int cur = 0;
        CGContextSetLineWidth(context, g_Ink_Width);
        float red = ((g_ink_color>>16)&0xFF)/255.0f;
        float green = ((g_ink_color>>8)&0xFF)/255.0f;
        float blue = (g_ink_color&0xFF)/255.0f;
        float alpha = ((g_ink_color>>24)&0xFF)/255.0f;
        CGContextSetRGBStrokeColor(context, red, green, blue, alpha);
        CGContextBeginPath( context );
        while( cur < cnt )
            PDF_POINT pt;
            PDF_POINT pt2;
            int type = [m_ink node: cur: &pt];
            switch( type )
                case 1:
                    CGContextAddLineToPoint(context, self.contentOffset.x + pt.x/m_scale, self.contentOffset.y + pt.y/m_scale);
                    cur++;
                    break;
                case 2:
                    [m_ink node: cur + 1: &pt2];
                    CGContextAddCurveToPoint(context, self.contentOffset.x + pt.x/m_scale, self.contentOffset.y + pt.y/m_scale,
                                             self.contentOffset.x + pt2.x/m_scale, self.contentOffset.y + pt2.y/m_scale );
                    cur += 2;
                    break;
                default:
                    CGContextMoveToPoint(context, self.contentOffset.x + pt.x/m_scale, self.contentOffset.y + pt.y/m_scale);
                    cur++;
                    break;
        CGContextStrokePath( context );
Thank you a lot for your help
Can't draw a point for annotation 9 years 10 months ago #11244
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
In PDF document ,there is no pixel concept. If you want draw a point,here is same way
1.Draw line ,end point value subtract start point value equal the point's diameter where you want to draw
2.Add a image ,the image is 1 pixel like a point
