Edit Boxes Issues 9 years 6 months ago #11711
  • JulienP88
  • JulienP88's Avatar Topic Author
I have a pdf-form with multiple fields. Is it possible to step between the fields?
Furthermore is it possible to lock the field's position? If I select a field the keyboard is coming up and if i want to scroll the pdf, I am moving the fields/annotations.
One last question: if I am opening the keyboard clicking on a field, the keyboard sometimes overlays the fields. Can I scroll the pdf to the visible area which is not covered by the keyboard?
Edit Boxes Issues 9 years 6 months ago #11734
you can check the new demo version ( 3.8.0 ) that fix the keyboard issue: the view is scrolled automatically.
About field lock, you can use the [PDFAnnot setLock], that does exactly what you need.
