Save font method not working 9 years 2 months ago #12323
  • Pja
  • Pja's Avatar Topic Author
When in the App_init() method the font Arial is saved Global_SaveFont the given method is returning nothing.
The applications hangs and further methods are not executed. What could be the reason for this?
Save font method not working 9 years 2 months ago #12324
this error could be caused by a wrong font path or if the font file doesn't exist
Save font method not working 9 years 2 months ago #12328
  • Pja
In the following code
strcpy( dst, dd1 );
strcat( dst, "/Arial.ttf" );
if( ![fileManager fileExistsAtPath:NSString alloc] initWithUTF8String:dst )
if( Global_SaveFont("Arial", dst) )
Global_fontfileListAdd(dst);
else Global_fontfileListAdd(dst);
strcpy( dst, dd1 );
strcat( dst, "/Verdana.ttf" );
if( Global_SaveFont("Verdana", dst) )
Global_SaveFont creates the mentioned font in Cache folder. While executing this method the app hangs.
Save font method not working 9 years 2 months ago #12329
  • Pja
Is there anything else that i am missing as a part of initialisation?
Save font method not working 9 years 2 months ago #12330
It seems you are using an old version of the SDK, because the code mentioned by you has been removed.
I suggest to download the updated version here: www.radaeepdf.com/download/file/83-radaeepdf-3-8-1
Other about integration: be sure to include cmaps and fdat folders into your project using "Create folder references" option
