Single - Double Tapped Issue 9 years 4 weeks ago #12554
  • tommaso
  • tommaso's Avatar Topic Author
With Rdpdf lastest version (5.8.1)
single and double tap event return different position seems there is an issue with doubletap position.
- (void)OnSingleTapped:(float)x :(float)y
- (void)OnDoubleTapped:(float)x :(float)y
Single - Double Tapped Issue 9 years 3 weeks ago #12567
are you experiencing this issue on a particular device/simulator?
Single - Double Tapped Issue 9 years 3 weeks ago #12568
  • tommaso
yes with different devices Ipad 2 , Ipad Mini2, Ipad Mini 3, Ipad Pro (no simulator)
Tks
Single - Double Tapped Issue 9 years 3 weeks ago #12577
in PDFView class, you can try to fix the OnDoubleTap implementation in this way:
replace:
if (m_delegate) {
        [m_delegate OnDoubleTapped:[touch locationInView:self.window].x :[touch locationInView:self.window].y];
with:
if (m_delegate) {
        CGPoint point= [touch locationInView:[touch view]];
        point.x *= m_zoom;
        point.y *= m_zoom;
        [m_delegate OnDoubleTapped:point.x :point.y];
In this way the CGPoint is created using the correct container
The following user(s) said Thank You: tommaso
Single - Double Tapped Issue 9 years 3 weeks ago #12578
  • tommaso
Hi Emanuele, Ok
Thank you for support
