Changing color of highlight annotation 8 years 7 months ago #13260
  • arathi
  • arathi's Avatar Topic Author
Highlight annotation always highlights in yellow color. Even if I give some other color code to
-(BOOL)vSelMarkup:(int)color :(int)type
this method, its getting highlighted in yellow color. So how to change the color for Highlighting using objective- C language?
Changing color of highlight annotation 8 years 7 months ago #13261
To solve your problem you can do two things: you can add color parameter to SetSelMarkup method in PDFVPage class or you can change "annotHighlightColor" uint variable that is in PDFVPage class too.
Hope it helps.
Changing color of highlight annotation 8 years 7 months ago #13262
  • arathi
SetSelMarkup Method Worked. Thank You :)
