form becomes blank on double click 8 years 5 months ago #13520
  • pooja
  • pooja's Avatar Topic Author
In the following pdf, after double or multiple clicking on the form, it displays a white blank screen. This works fine for android, but not for iOS. Please suggest how can we fix it.
Pooja
Last edit: by pooja.
form becomes blank on double click 8 years 5 months ago #13523
I've done some tests with iPhone, iPad and simulator and they never display a white blank screen. Can you tell me please which RDPDFLib's version are you using? Have you got the same issue with demo app?
form becomes blank on double click 8 years 5 months ago #13526
  • pooja
I am using v1.3.0
form becomes blank on double click 8 years 5 months ago #13528
  • pooja
the form appears like this
form becomes blank on double click 8 years 5 months ago #13532
we checked your pdf file with the Cordova plugin and it seems ok.
Have you changed or removed some code regarding font management?
I also suggest to remove the plugin and try to reinstall the latest version.
Here is how appears your pdf file:
form becomes blank on double click 8 years 4 months ago #13535
  • pooja
I have made these changes www.radaeepdf.com/forum/Android-developm...-inputted-data#13360 should that affect?
