Auto Calculate formlua 8 years 3 months ago #13673
  • pooja
  • pooja's Avatar Topic Author
Is there a functionality in Radaee which supports to calculate a formula and fill a field according to it, as in MS Excel?
For ex. if I have a pdf with two text fields and third one has formula to show sum of first two, then it should auto calculate it, once the first two are filled.
It this functionality supported? Please let me know.
Pooja
Auto Calculate formlua 8 years 3 months ago #13676
our SDK support Javascript execution on form fields.
You can use this feature to fill your field with a specific value.
You can check the attached document to find JS supported methods
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Auto Calculate formlua 8 years 3 months ago #13680
  • pooja
Ok. I'll check it. Thanks.
