Difference between Swift and Objectiv-C Version 7 years 11 months ago #14060
  • MrSmith
  • MrSmith's Avatar Topic Author
Hi there,
i noticed there are a lot a lot of differences between the Objectiv-C and Swift version. For example the whole annotation utilities are different between these two version. Is there a reason for this?
Thanks in advance
Difference between Swift and Objectiv-C Version 7 years 11 months ago #14061
The Swift framework relies on the same code of the Cordova and Xamarin plugins.
It's exposing very simplified API as customers was mainly asking for a simple way to do few actions on PDF documents.
The swift module is provided with full Objective-C sources on GitHub and with Apache2 license: you're allowed to modify it and expose all the Objective-C API.
If you need some specific features and don't wan't to work on you own, I invite you to open a support ticket here www.radaeepdf.com/support and address it to sales team.
Difference between Swift and Objectiv-C Version 7 years 11 months ago #14066
The new RadaeePDF project's version is available here
Difference between Swift and Objectiv-C Version 7 years 5 months ago #14264
  • apdeveloper
  • apdeveloper's Avatar
How can we use the objective -c feature in swift can you show me one example.
