Missing features in the Swift libraries 7 years 5 months ago #14276
are you able to render correctly your pdf file using demo project? (not your custom project)
Could you please share your pdf file to investigate on this issue?
The following user(s) said Thank You: apdeveloper
Missing features in the Swift libraries 7 years 5 months ago #14277
  • apdeveloper
Below is the attached pdf file which i am opening in your dummy project but the text is not visible you can open the same pdf in google chrome or any other pdf viewer all the text will be visible to you.
Missing features in the Swift libraries 7 years 5 months ago #14278
we found the issue: you should create "stdFont" and "stdRes" folders in "fdat".
In stdRes folder you should move 00,01,02,03,04,05,06,07,08,09,10,11,12,13 files.
In stdFont folder you should move the .ttf files.
We will fix this project structure issue both in demo project and Swift guide.
Thank you for your report.
Missing features in the Swift libraries 7 years 5 months ago #14279
  • apdeveloper
Thank you for your valuable support your solution provided is working fine.
Try to fix this issue as soon as possible and provide an update and release for the same.
Missing features in the Swift libraries 7 years 5 months ago #14280
we just updated the Swift module with this fix
