Missing features in the Swift libraries 7 years 5 months ago #14270
if you need some customizations, you could open a new ticket and address it to sales department with the list of needed features and some screenshot to better understand how to implement them.
About MakeFile, you could edit RadaeeLib project (Obj-C) then open Terminal, go to Swift/RadaeeSwift/Obj-C and run "make" command from terminal to create the a new libRDPDFLibSDK.a file that will replace the same file into Swift project.
The following user(s) said Thank You: apdeveloper
Missing features in the Swift libraries 7 years 5 months ago #14271
  • apdeveloper
Thank you so much for the answer.
Not able to view the text but i am able to see the table and images in the pdf so can you please tell me what is the issue.
File which i am saving in to document directory after downloading it from the server that is opening and showing me the table and images but not showing me the text but when i am opening the pdf from bundle folder or asset folder that is working fine.
Last edit: by apdeveloper.
Missing features in the Swift libraries 7 years 5 months ago #14272
It seems that you're missing fonts' resources in your project.
May you double-check, please?
Missing features in the Swift libraries 7 years 5 months ago #14273
  • apdeveloper
I have added the Radaee folder into my project.
Missing features in the Swift libraries 7 years 5 months ago #14274
Please take a look at this Knowledge Base article that shows how to include the Swift module, it will help you to better understand the necessary steps and resource needed: www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=142
For example, “cmaps” and “fdat” folders (that are folders with resources and fonts) must be included using “Create folder references” option.
Missing features in the Swift libraries 7 years 5 months ago #14275
  • apdeveloper
My directory structure and the all the files and folder are placed exactly same as described in the link you have share still not getting the text.
