How to get the x and y position when their is underline,highlight and strikeout 6 years 11 months ago #14455
  • apdeveloper
I want to get the position of x and y when underline,highlight and strikeout is done on pdf like when we click on annotation delegate method of did tap annot function is getting called and x and y position is getting log so similarly that x and y pos should get log when i start to select the text and do underline,highlight and strikeout.
How to get the x and y position when their is underline,highlight and strikeout 6 years 11 months ago #14457
Dear user:
you can get the position from PDFLayoutView.onTouchSelect(), follow the code line:
case MotionEvent.ACTION_UP:
start point:
m_hold_x
m_hold_y
end point:
event.getX();
event.getY();
How to get the x and y position when their is underline,highlight and strikeout 6 years 11 months ago #14458
  • apdeveloper
How to call this variable or method from RDPDFviewcontroller :
start point:
m_hold_x
m_hold_y
end point:
event.getX();
event.getY();
and one more thing i am using the older version of Radaeepdf so can i call this function when selector is clicked
-(bool)OnSelTouchBegin:(CGPoint)point.
How to get the x and y position when their is underline,highlight and strikeout 6 years 11 months ago #14459
Dear apdeveloper,
You could check OnSelEnd method in RDPDFViewController that will give you 4 coordinates. x1 and y1 are start selection's coordinates and x2 and y2 are end selection's coordinates.
Last edit: by federico.
How to get the x and y position when their is underline,highlight and strikeout 6 years 11 months ago #14464
  • apdeveloper
While adding the annot i am setting the name for the annot but still i am not getting the index of annot
-(void)vRemoveSelectorAnnot:(PDFAnnot *)annot
[self setReadOnly:false];
if (![self canSaveDocument]) {
[self vAnnotEnd];
NSLog(@"bbbbb---");
return;
m_status = sta_annot;
if( m_status != sta_annot ){
NSLog(@"aaaaa---");
return;
NSLog(@"Selected Page Annot NAme----%@",annot.getName);
[self setModified:YES force:NO];
//Action Stack Manger
PDFPage *page = [m_doc page:m_cur_page];
[actionManger push:ASDel alloc] initWithPage:m_cur_page page:page index:annot.getIndex;//Getting Error at this line while gtting index
[annot removeFromPage];
[self vAnnotEnd];
[m_view vRenderSync:m_cur_page];
[self refresh];
[m_doc save];
NSLog(@"Remove AnnotComplete---");
How to get the x and y position when their is underline,highlight and strikeout 6 years 11 months ago #14465
in which case are you calling your vRemoveSelectorAnnot method?
You said "While adding the annot" but this code is removing the annotation.
