Can we do underline,highlight and strikeout on scan document 6 years 9 months ago #14632
  • apdeveloper
Dear Team,
Currently i am doing underline,highlight and strikeout but it is not happening so can we do underline,highlight and strikeout on scan document
Can we do underline,highlight and strikeout on scan document 6 years 9 months ago #14633
Dear apdeveloper,
This also happen with RadaeePDF's demo document?
Can you share us your document?
Can we do underline,highlight and strikeout on scan document 6 years 9 months ago #14643
AddAnnotMarkup method need char index as input.
some scan image page has no any chars, and some scan image write invisible chars under the scan image(mostly it is generated by OCR engine).
the second type scan image PDF file can markup texts.
Can we do underline,highlight and strikeout on scan document 6 years 8 months ago #14644
  • apdeveloper
Dear Team,
Below is the attached sample PDF document in which we are able to do other annotation except Hightlight,Underline and strikeout.
Can we do underline,highlight and strikeout on scan document 6 years 8 months ago #14645
The file contains a scannerized page.
No text in it, so nothing to highlight.
Also the sticky note on the page says: "This is a sample page scanned at 200dpi and converted to PDF. It is not searchable. That is, all you see is the original image of the source document."
