iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 6 years 2 months ago #15016
  • Apparound
  • Apparound's Avatar Topic Author
I've followed your instructions but double tap zoom does not work.
It seems that I need to set also _g_zoom_step, because without a value the default is 0 and so it is not possible to zoom double tapping.
Is _g_zoom_step also mandatory? if so, possible values are 0 and 1? Again, how can I preserve the previous version's behavior?
Finally, can you please tell me if there are other mandatory setting for preventing regressions after updating to version 3.61?
Thanks a lot for your support
Last edit: by Apparound.
iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 6 years 2 months ago #15017
In previous version the zoom step had value 2 as default, now that the iOS SDK is aligned with Android version there's the new g_zoom_step global that permit you to set the zoom step value.
To reproduce old version's zoom behavior you should set g_layout_zoom_level. g_zoom_level and g_zoom_step in RDVGlobal class like this:
_g_zoom_level = 2; //double tap, (2-5)
_g_layout_zoom_level = 15; //pinch to zoom
_g_zoom_step = 2;
Every globals are mandatory to permit SDK working well, if you want to know more about all globals that SDK 3.61 has I suggest you to see our knowledge base here
