iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 5 years 10 months ago #15006
  • Apparound
  • Apparound's Avatar Topic Author
I've updated to version 3.61 from 3.58. In my settings I'm not using _g_layout_zoom_level.
Without setting it, pdf is not shown (try PdfViewer project and remove _g_layout_zoom_level = 11) and also tapping on a thumb results in a crash.
Is this setting mandatory from 3.61 version? what's the meaning of 11?
Last edit: by Apparound.
iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 5 years 10 months ago #15008
g_layout_zoom_level represents pdf viewer's maximum zoom level.
RadaeePDF CALayer 3.61 has now globals' name aligned with android, before variable's name was g_zoom_level and now g_layout_zoom_level
This value determines how large the content can be scaled. It must be greater than the minimum zoom scale for zooming to be enabled so if you're not interested in zooming feature you could just set maximum level (g_layout_zoom_level) as 1.
Last edit: by federico.
iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 5 years 10 months ago #15010
  • Apparound
In your PdfViewer project there are both settings with different values:
_g_zoom_level = 3; //double tap, (2-5)
_g_layout_zoom_level = 11; //pinch to zoom
removing the second causes the problems mentioned in the last post.
Are they both mandatory? or _g_zoom_level is obsolete and can be remove and_g_layout_zoom_level is mandatory?
Why they have different values?
Thanks for the support.
iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 5 years 10 months ago #15012
In 3.61 version or newer these globals are both mandatory because from this version globals in Android and iOS are aligned.
g_zoom_level global represent the max steps that double tap could to about zooming in and zooming out and it has to be a value between 2 and 5 included.
g_layout_zoom_level global determines how large the content can be scaled.
iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 5 years 10 months ago #15013
  • Apparound
So I have to use both. One last thing: is there a range of permitted values for g_layout_zoom_level? which value can be considered the default of the previous version? I would like to maintain the same behavior as before.
iOS PDFViewer (CALayer) 3.61 - g_layout_zoom_level 5 years 10 months ago #15014
If you would like to maintain the same behavior as before you should just set g_layout_zoom_level as was g_zoom_level before in RDVGlobal class:
_g_layout_zoom_level = 15; //pinch to zoom
