Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15109
i can't reproduce the 1st point issue about text note annotation. i believe you have not updated native library yet.
the 2nd point about ink annotation import is fixed right now, we will upload in later working days.
at last, ImportAnnot() is not recommended for undo/redo operation, because, some annotation did not support PDFAnnot.Export().
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15110
  • Damir Gibaev
  • Damir Gibaev's Avatar Topic Author
I believe i have updated library because original issue is not reproducing now. I will check our code working with notes.
We use Export/ImportAnnot only for Ink, Sel and Note annotations.
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15111
OK, i saw some new codes as old codes yesterday.
so, the next ios version shall fix your issue.
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15113
Dear user,
We've just updated Radaee iOS SDK's 3.71 beta 2 version that will solve your issue here .
You could also just update core lib
Please tell us if all works good
