Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15098
  • Damir Gibaev
  • Damir Gibaev's Avatar Topic Author
Hi everyone,
i've got some problems with importing ink annotations. I export ink annotation with PDFAnnot.export, get rect with PDFAnnot.getRect and then import annotation to the same page page.importAnnot(rect, data, dataLength). This is our Undo/Redo implementation.
Code works fine but on some PDF documents we have strange behaviour that imported annotation rotates and moves to another position.
Could you help with that?
Image in attachments, test PDF doc in dropbox www.dropbox.com/s/68b2e61ulwp5w04/A17_FlightPlan.pdf?dl=0
Radaee SDK iOS ver 3.57, premium license
Last edit: by Damir Gibaev.
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15099
can you check return value of
Page.getRotate()?
i guess it may cause error, when 2 pages has not same rotate angle.
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15100
we have a native library fix for you.
we will update in this week.
The following user(s) said Thank You: Damir Gibaev
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15101
  • Damir Gibaev
Thanks! I will wait for it.
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15106
Dear user,
We've just updated the new Radaee iOS SDK's beta version that will solve your issue here
You could also just update core lib
Please tell us if all works good
Ink annotation moves and rotates after ImportAnnot 6 years 1 month ago #15107
  • Damir Gibaev
Thanks, Federico! Now import works fine for ink annotations. But i noticed other problems with this document:
1. Text annotation also moves after Import:
2. Some ink annotations were clipped after import, and some annotations (like dots) just disappeared:
