PDF not fit to screen in (open multi apps in same window) iPad 6 years 2 weeks ago #15137
  • mobileapps@dewa.gov.ae
  • mobileapps@dewa.gov.ae's Avatar Topic Author
Dear Team,
When I opened multi apps in iPad, RadeePDF's PDF not fit to screen. But if I opened pdf in PDFKit its fit to screen.
How can Achieve this? Please guide me. For your reference I attached both screen shot.
First one is RadeePDF, second one is PDFKit.
Thanks in advance.
Regards
Ponlingam S
PDF not fit to screen in (open multi apps in same window) iPad 6 years 2 weeks ago #15138
you should take a look at screenRect method in RDLoPDFViewController that is used to set the layout size.
The current implementation uses [[UIScreen mainScreen] bounds], you should try to change it to the current view size.
