Blank Document - PDF not opening in Radaeepdf SDK. 5 years 3 months ago #15462
  • mobileapps@dewa.gov.ae
  • mobileapps@dewa.gov.ae's Avatar Topic Author
Dear Radaeepdf Team,
                   I was trying trying to open annotated pdf in Radaeepdf SDK, its open as blank document. All contents are missing. But if i open in adobe reader its working fine. Also if i opened that pdf in my macbook pro and re uploaded in radeePDF it was working. Can anyone of you help me to solve this issue? It will be very helpful. Please.
Thanks in Advance.
Regards
Ponlingam S
Blank Document - PDF not opening in Radaeepdf SDK. 5 years 3 months ago #15463
Hi Ponlingam,
Which Radaee's SDK version are you using? Could you please share us the pdf document that cause that issue?
Blank Document - PDF not opening in Radaeepdf SDK. 5 years 3 months ago #15464
It seems that your file is not embedding any of the used fonts.
You can fix it:
- embedding fonts in your files
- adding the required not-standard fonts in your application: pay attention to the font's license!
