how fill color in rect ? 13 years 6 days ago #3295
  • truculent
thank youuuuuuuuu DEaaaaaaaar radaeeeeeeeeee <3 :* : * <3 <3 <3
now is there any way for change the color of fill ?
whene i change another Value [ again alpha back to 1 :( ]
how fill color in rect ? 13 years 5 days ago #3304
you can get stroke color and set back to annotation with different alpha.
and then set fill color.
it can't change alpha value if set fill color only,
how fill color in rect ? 13 years 5 days ago #3306
  • truculent
thank you
but can you give me another sample for anoter color?
why when i change grect color & fill color in addAnoot-xxxxxx()
again my rect with alpha 1
but you last value have correct alpha!
i cand undrestand how youndo it!
how fill color in rect ? 13 years 5 days ago #3310
for add rect annotation with fill color:
Page_AddAnnotRect( page, mat, rect, strokecolor_and_alpha, fill_color_with_255_alpha );
for add rect annotation without fill color:
Page_AddAnnotRect( page, mat, rect, strokecolor_and_alpha, fill_color_with_0_alpha );
set alpha for rect annotation:
int clr = Page_GetAnnotStrokeColor(page, annot);
clr &= 0xFFFFFF;//clear alpha value;
clr |= (alpha<<24);//set alpha value, alpha value is in range [0,255];
Page_SetAnnotStrokeColor( page, annot, clr );
set all values:
int stroke_clr = Page_GetAnnotStrokeColor(page, annot);
stroke_clr &= 0xFFFFFF;//clear alpha value;
stroke_clr |= (alpha<<24);//set alpha value, alpha value is in range [0,255];
int fill_clr = 0xFF000000 | your_fill_color;
Page_SetAnnotFillColor( page, annot, fill_clr );
Page_SetAnnotStrokeColor( page, annot, stroke_clr );
Page_SetAnnotStrokeWidth( page, annot, stroke_width );
