how fill color in rect ? 13 years 6 days ago #3265
  • truculent
dear radaee our problem is :
when use : Page_addAnnotRect(page, mat, &rect, g_rect_Width * m_scale, g_rect_color, fill_color);
we fill rect with a color with alpha 1 :|
for example when draw rect with red color it fill with red but with alpha 1 and not transparent :(
you hint me with your Hint :
CGFloat clr[4];
clr[0] = //red, ... range [0,1];
clr[1] = //green, ... range [0,1];
clr[2] = //blue, ... range [0,1];
clr[3] = //alpha, ... range [0,1];
CGContextSetFillColor(m_ctx, clr);
CGContextFillRect(m_ctx, CGRectMake(...));
i change only clr[3] = 0.5;
but not different in my alpha in fill rect !
also when i change it my frame of reader's color change (not rect color change )
Last edit: by patel_patel_patel.
how fill color in rect ? 13 years 6 days ago #3266
OK, the alpha channel must be in stroke color(g_rect_color).
alpha channel in fill_color is 0 if no filling, or 255 if has filling.
how fill color in rect ? 13 years 6 days ago #3274
  • truculent
i really cant understand your mean :(
your mean there is no way to fill color with alpha ( for EXM : 0.5 ) ?
i want to draw rect Like your Android SDK [in android SDK when draw rect they fill with e color with custom alpha]
how fill color in rect ? 13 years 6 days ago #3275
annotation just has 1 alpha information, both for stroke and fill or other graphics.
parameters has 2 color.
alpha informatioin is in sroke color.
fill color use same alpha value to stroke if fill_color alpha value is not zero.
how fill color in rect ? 13 years 6 days ago #3277
  • truculent
can you help me :|
i try all of way but result is
upload7.ir/images/16534463092081659262.png
how fill color in rect ? 13 years 6 days ago #3278
just try:
Page_addAnnotRect(page, mat, &rect, g_rect_Width * m_scale, 0x80FF0000, 0xFF0000FF);
The following user(s) said Thank You: patel_patel_patel
