licensing 12 years 4 months ago #5706
  • moontech
  • moontech's Avatar Topic Author
I already purchase Premium version of this library.
And when i go for update my old library with new library so need to purchase again,
licensing 12 years 4 months ago #5707
no, you no need.
you just need:
--replace rdpdflib.so
--replace package com.radaee.pdf
--and com.radaee.view if you are using it.
licensing 12 years 3 months ago #5887
  • moontech
which files are necessary for pdf view and add and remove annotation
licensing 12 years 3 months ago #5940
  • moontech
Before this version ,i used 1.1
and in this version most of methods changed for annoatation.
Can you inform me where need to change in existing library's classes ?
Update fast.
Last edit: by fischer.
licensing 12 years 3 months ago #5941
You need to update the packages:
com.radaee.pdf
com.radaee.reader
com.radaee.util
update the libs folder (native lib + jar)
licensing 12 years 3 months ago #5942
  • moontech
i did this but method compare to 1.1 changed.
So not getting propare output from new version
