Blue Pages 10 years 2 months ago #10643
  • josalo
  • josalo's Avatar Topic Author
HI, Im using the demo SDK and considering buying it. I implemented PDFViewPager sucessfully in my android app but i can only see the first page. The rest are in blue. Is this a limitation of the demo version?
Blue Pages 10 years 2 months ago #10644
I suspect it could be an issue related to your code or to the pdf you are working with.
May you upload the file so we could check it?
Blue Pages 10 years 2 months ago #10645
  • josalo
Im trying to make it work as an React Native UI Module. It happens to me with several PDFs, im attaching you one of them. Page 3 renders blue.
dl.dropboxusercontent.com/u/2515162/GPA-...aginitis-2016-OK.pdf
Here is my code:
public class PdfViewManager extends SimpleViewManager<RelativeLayout> {
    public static final String REACT_CLASS = "RCTRadaeePDF";
    private ThemedReactContext context;
    private Document m_doc;
    private PDFFileStream m_stream;
    private RelativeLayout m_layout;
    private PDFViewPager m_pager;
    public PdfViewManager(Activity mActivity) {
        Global.Init(mActivity);
        Global.debug_mode = false;
    public String getName() {
        return REACT_CLASS;
    public RelativeLayout createViewInstance(ThemedReactContext context) {
        m_layout = (RelativeLayout) LayoutInflater.from(context).inflate(com.radaee.viewlib.R.layout.pdf_fragment, null);
        m_pager = (PDFViewPager)m_layout.findViewById(R.id.pdf_pager);
        this.context = context;
        return m_layout;
    @ReactProp(name = "src")
    public void setSrc(RelativeLayout view, @Nullable String src) {
        m_doc = new Document();
        m_stream = new PDFFileStream();
        boolean ok = m_stream.open(src);
        if( !ok ) return;
        int ret = m_doc.OpenStream(m_stream, null);
        if( ret != 0 )
            m_doc.Close();
            m_doc = null;
            return;
        m_pager.PDFOpen(m_doc,1);
    @ReactProp(name = "pageNumber")
    public void setPageNumber(RelativeLayout view, int pageNum) {
        m_pager.setCurrentItem(pageNum);
Last edit: by josalo.
Blue Pages 10 years 2 months ago #10647
I have checked your pdf with the View Pager of the demo library (PDFViewPager) and it works properly.
What version of the library are you using? Can you reproduce the issue with the last version of the demo project?
www.radaeepdf.com/download/download-prev.../34-radaeepdf-362rc3
