Can't finish registration 13 years 2 weeks ago #3136
  • Ivanov
  • Ivanov's Avatar Topic Author
I just registered here to try your solution. But I can't finish registration process to download SDK. When I go by link from email it shows "Registration failed: Verification code not found."
Thanks and Best Regards,
Aleksander.
Last edit: by redwards1955.
Can't finish registration 13 years 2 weeks ago #3145
Dear Aleksander, what do you mean with "registration"?
Have you bought a license? May you send to This email address is being protected from spambots. You need JavaScript enabled to view it. an email with the order number?
The order number is a string like GEA124341-1245-xxx.
To register your application and get the activation key you should:
- connect to www.androidpdf.mobi/shop/key-request
- write the order number and numeric pin you've received via email after the purchase
- press the "Order status" button
In the form you will get:
- write the application package name, the pin again
- submit the form
- validate it
- get back your key
