Android PDF Viewer SDK 3.8.1beta 9 years 9 months ago #11326
A new beta version 3.8.1beta1 has been published.
native library
- NEW new interface: Annotation.SetStrokeDash()
- NEW interface DocGState.SetStrokeDash() to support dash stroke lines creation.
parameters defined in PDF-Reference 1.7
- FIX issue with horizontal line in spec PDF file
Android PDF Viewer SDK 3.8.1beta2 9 years 9 months ago #11366
A new beta version 3.8.1beta2 has been published.
3.8.1beta2
native library
- NEW marked PDFReader classes as Deprecated.
- ENHANCED support Arabic finding without case matching
- ENHANCED Global.Init pass Context object (the Context object must be derived from ContextWrapper, otherwise it may cause a crash in native part using ContextWrapper as parameter, because Context.getPackageName() is abstract method, without implementation)
